It is currently Thu Sep 02, 2010 7:36 pm
View unanswered posts | View active topics
Great 300M
Post subject: Re: door lock solenoid Posted: Wed Oct 16, 2002 10:51 am |
| 300M Guru |
I guess you didn't go for the extended warranty then? I know you were interested for a while. <p></p><i></i>
300mtech
Post subject: Re: door lock solenoid Posted: Wed Oct 16, 2002 8:19 pm |
| Rookie |
Sorry to say, but if it is out of warranty (depending how far out)<br>you are pretty much on your own. I change those alot. You are correct in saying the are inferior. The lowest bid gets the job. If you don't use that door much, you can always remove the panel and unplug the electrical connector. The lock will still work manually. Just an idea. <p></p><i></i>
300mtech
Post subject: Re: door lock solenoid Posted: Wed Oct 16, 2002 9:12 pm |
| Rookie |
From start to finish, it takes me about a half an hour to do.<br>Removal of the door panel is pretty straight forward. Undo the screw in the armrest and I think there is one under the door handle. There are also some screws on the bottom of the panel. Grab a loose part of the panel and give a quick and firm yank! It will sound like the door is breaking in half, but it is the clips that are releasing from the door. Sometimes you will break a clip or to. No big deal to replace. After freeing the panel, pull back only a few inches so you can release the<br>door handle actuator rod from the handle. Be very careful here.<br>If you break the clip, you will need an entire door panel!!!!!<br>The handle cannot be replaced seperatley. Unplug the electrical connectors and put door panel aside. (Make sure the window is in the "up" position before panel removal.)<br>The actuator has 3 torx head bolts holding it in. They are located right near the latch of the door (where it latches on to the body.) First, reach in and unplug the actuator, and release the actuator rods, 3 of them I believe. Unbolt it and pull it out. Gotta be a little bit of a contorsionist, but it comes out. By the way, after panel removal, pull back the water barrier. First time it always looks scary. Not really a big deal though. Just take your time and be gentle with the plastic. Hope this helps. Let me know how you make out. <p></p><i></i>
lode300m
Post subject: Re: door lock solenoid Posted: Fri Jan 03, 2003 2:30 am |
| Newbie |
Replaced my first solenoid this evening (drivers door). Overall it wasnt that hard to do. Bear in mind that I was working outdoors in the dark with a flashlight in 35 degree weather. I got the whole thing done in prolly 45min to an hour.<!--EZCODE EMOTICON START :headbang --><img src=http://mywebpages.comcast.net/rpowelljr/headbang.gif ALT=":headbang"><!--EZCODE EMOTICON END--> <br><br>Finally! no more "bzzzzzzzzzzztttt" I am a patient man, but that was getting seriously annoying. The part cost me $81 + tax. (Other dealers wanted as much as $97.50) <!--EZCODE EMOTICON START :eek --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/eek.gif ALT=":eek"><!--EZCODE EMOTICON END--> <br><br><br>'99 Deep Slate over Agate; nonPHP; chrome razors; 66k.<br> <p></p><i></i>
redpicker
Post subject: Clips (P/N Request) Posted: Fri Jan 03, 2003 1:09 pm |
| Newbie |
Anybody got the P/N for the door panel clips handy. I know it was posted at one time, but I cannot find it. I have a buddy who is going to a parts dealer and I want to see if he can pick me up some.<br><br>Thanks<br><br>chris north <p></p><i></i>
lode300m
Post subject: Re: Clips (P/N Request) Posted: Fri Jan 03, 2003 9:23 pm |
| Newbie |
Easy - $50!?!.. damb, well as least now I know for the future.<!--EZCODE EMOTICON START :thumbsup --><img src=http://mywebpages.comcast.net/rpowelljr/thumbsup.gif ALT=":thumbsup"><!--EZCODE EMOTICON END--> Anyway I believe I printed out the instructions from one of the threads somewhere on this board. If I cant find the thread again I will retype it here from my printout.<br><br>I didnt have to replace any clips, but it was a pain unsnapping the clips from the broken motor. I have fairly large hands so that didnt help. Oh, and I would recommend doing it in the daylight cause moving the dambed flashlight every 15 seconds so I could see what the hell I was doing was the biggest obsticle.<!--EZCODE EMOTICON START :doh --><img src=http://mywebpages.comcast.net/rpowelljr/doh.gif ALT=":doh"><!--EZCODE EMOTICON END--> <p></p><i></i>
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
