  • My journey through my Swap to '02 Electronics LOTS OF PICS!!
 #341405  by Strmvt
 January 11th, 2015, 11:29 am
Changed out the clock spring and air bag
Also changed out the shifter assy due to the brake interlock push rod being broke when I pulled the dash.
 #341522  by Strmvt
 January 14th, 2015, 7:25 pm
Got everything I need to finish the swap except the engine hoist.
Replacing the harmonic balancer.
Front crank seal
Inner tie rod bushings yes Bob they have the washers Image
Intake gasket set and cam locks
Harmonic Balancer puller
Water pump
 #341614  by Strmvt
 January 17th, 2015, 10:21 pm
Got more done on the R/T today
Motor out
On the floor
Old flywheel
Cam caps off
Cam locks bolted on
Flywheel off rear main seal no leaks
Motor back in forgot to take a pic of 02 flywheel mounted
01 cam sprocket
01 sprocket off
Imagem
Timing marks lined up
Balancer puller on
Balancer off
Water pump off and where it was leaking from
New water pump mounted
Timing belt back on as well as the covers
 #341619  by tafi300M
 January 18th, 2015, 5:41 am
Respect. :headbang Does your sister still talk to you for taking over her garage?
 #341623  by Strmvt
 January 18th, 2015, 10:33 am
tafi300M wrote:Respect. :headbang Does your sister still talk to you for taking over her garage?
Thanks Tafi, definitly allot of work going on. Yea she does lol even made me text her when I got home lol
 #341663  by Strmvt
 January 20th, 2015, 5:49 am
Had to buy a torch to heat up the new balancer to be able to press it on.
Also got the trans harness changed.
Only got the fuel line and fuel return line to change out and inner tie rod bushings, need to get a socket lol don't have a 22m socket.
After that put the top of the motor back together. Then hopefully turn the key and not have to much trouble and she starts up Image Image Image
 #342167  by Strmvt
 January 30th, 2015, 3:36 pm
You'd be right. Had to get a different alternator due to the differences in plug type btwn 01 and 02 model years. Found this locally thanks to Craig figured might as well lol. Just need to clean it up before install it.
 #342182  by Strmvt
 January 30th, 2015, 11:42 pm
Just need to put in the starter solder the alternator wires and mod the plenum brackets for the spacer get nuts and bolts for the front L brackets and get a new radiator.
