  • Swap pre 98 3.5 non-interference CIron block into 01 300M
 #349448  by bobczap30
 September 4th, 2015, 6:29 am
My 2001 300M has a very bad top end engine noise/rattle. Engine starts, runs, idles. I bought the car in this condition because I have a 97 intrepid parts car with a 3.5. I have subsequently been told that the cast iron block engine will bolt up but will not run with the 2001 electronics. Is this correct or is there anyone who has made this work. I would like to complete this project without spending another $1000 on an HO engine.
 #349453  by paintballdude05
 September 4th, 2015, 7:42 am
There are a lot of differences between the two engines, it's not really worth it to try and swap it out.
 #349466  by paintballdude05
 September 4th, 2015, 1:49 pm
bobczap30 wrote:Based on the symptoms of the HO engine in the car, any suggestions on how to diagnose and repair it?
There are a few things, but the rockers can be noisy on these cars. You can replace the whole rocker assembly for less than $500 which isn't too bad. A good quality oil filter helps lessen the noise at startup.
 #349467  by FIREM
 September 4th, 2015, 1:51 pm
Post up a video.......
Not a candidate to swap iron block/aluminum block....
 #349481  by Sonicrob
 September 4th, 2015, 6:31 pm
It has been done before. Check out the video.
 #349502  by FalKen
 September 5th, 2015, 12:17 pm
bobczap30 wrote:Thanks FalKen, for the info and redirect to the article. Unfortunately it says that I'm not authorized to use the forum.
join the paid members club, well worth the $$$. you will be finding lots of answers to lots of ????'s in the knowledge base.
 #349736  by bobczap30
 September 10th, 2015, 11:20 am
Listening to it making the video, it now sounds like a rod knock to me.
I found a 2002 300M engine with 135k for $500.
Are there any issues that I should be aware of when using the 2002 engine in my 2001 300M?
 #349843  by bobczap30
 September 11th, 2015, 9:55 pm
Finally got access to paypal account and got my membership. I didn't realize that the article that you suggested I read, Ken, was what I was asking in my post with my video. So thanks again. Glad I joined! I think I'll look for an 01 engine.
 #349848  by LUNAT1C
 September 11th, 2015, 10:56 pm
An 01 engine will be plug-n-play. 02 engine will need the 01 flywheel, plenum, EGR system, wiring, etc. It does sound like that engine is done, does not at all sounds like lifter noise.
 #349959  by bobczap30
 September 15th, 2015, 6:08 pm
I found a 99 300M with about 100k miles that's been hit for $300. Engine runs and sounds OK. Will the 99 engine be an easy (plug and play) install in my 2001 300M?
 #349962  by FIREM
 September 15th, 2015, 7:19 pm
99-01 Plug and Play Swap.
 #350045  by hrmwrm
 September 17th, 2015, 7:48 pm
bobczap30 wrote:I found a 99 300M with about 100k miles that's been hit for $300. Engine runs and sounds OK. Will the 99 engine be an easy (plug and play) install in my 2001 300M?
just change out the tb/wp for new if you don't know when it was last done.
otherwise, it's a bolt in.
