  • Fog lights upgrade
 #365870  by ranger
 March 19th, 2017, 9:06 pm
Re: Yellow lamps. With black and white photography, using a yellow filter would block out some blue light frorm distant scenery. It worked. From this it was thought that yellow foglights would be effective. The main benefit of low mounted fog lights is to get the beam down under the fog or rain to prevent most of the light from bouncing back to your eyes. All the yellow lenses did was to reduce the effective light. Bottom line, clear lens is a good as it gets.
 #365916  by Sonicrob
 March 21st, 2017, 5:04 pm
M-Pressive wrote:I installed a set of projectors in mine, will be testing them in a couple weeks. Not expecting much though.
Did you ever get around to doing this? How effective are your fogs at night?
 #365917  by M-Pressive
 March 21st, 2017, 5:07 pm
They are way brighter than the stock setup. I will get some pics when I pull the car back out.
Sonicrob liked this
