  • DRL module - Finally Done
 #74718  by kumiyer
 February 27th, 2005, 6:40 pm
Did a search and could not find the P/N. Anybody know the P/N for the DRL module and how much it cost???. Is this module made by MOPAR. Did it ever some standard on M's. Thanks
 #74719  by 99300mricva
 February 27th, 2005, 7:37 pm
 #74722  by kumiyer
 February 27th, 2005, 8:28 pm
Thanks Rob, In 4 days I can see better during day time :lol:
Am just curious, What car was this module made for?? Is it the Special
 #74724  by vegas
 February 27th, 2005, 9:51 pm
I think DRL is mandatory in Canada or something, so provisions had to be made for the M to be readily available with DRL. ANY M can use this module, it plugs into the Junction Block, you can see the spot labeled for it behind the endcap where the fuses are.
 #74735  by 99300mricva
 February 28th, 2005, 5:02 am
Its a universal module for all 2nd Generation LH Cars 1998 - 2004.
 #74752  by kumiyer
 February 28th, 2005, 3:24 pm
Just wanted to inform people who want this module. The cheapest price I could find was from Rick Hendrick. $66.50. Ask for Jeff and tell him Kumar sent you.
Anybody else find this part for cheap, let me know?? Rick Hendrick will match that price for me.
 #75548  by KPM
 March 13th, 2005, 1:56 am
My local 5 Star quoted me $101. Don't buy one in Greenville.
 #75556  by Red Baron
 March 13th, 2005, 10:09 am
I have decided to remove mine because I am adding some custom high beam bulbs from Dan Stern that are not suited for DRL use. My DRL is modified with the 4 headlight mod to keep the DRLs ON even when the low beam headlights are on.
Is anyone interested in this modified DRL module for $50
 #75563  by KPM
 March 13th, 2005, 12:34 pm
I am. I'll PM you.
 #75565  by kumiyer
 March 13th, 2005, 1:18 pm
Don, how did you do the mod to your DRL module. I have seen some other members do it as well. I would like my high beam to stay on even when my low beams on. Thanks
 #75568  by Red Baron
 March 13th, 2005, 1:30 pm
kumiyer wrote:Don, how did you do the mod to your DRL module. I have seen some other members do it as well. I would like my high beam to stay on even when my low beams on. Thanks
It is done by removing one of the pins.
Rob has a great how to here.
http://public.fotki.com/99300mricva/300 ... me_runnin/
If you look at the second picture it shows the six pins.
In that picture it is the bottom left pin that has to be removed.
 #75584  by M-Pressive
 March 13th, 2005, 7:59 pm
Don,
You sell the DRL yet. I will take it if not.
 #75794  by kumiyer
 March 16th, 2005, 4:20 pm
Alright I have the DRL in and the high beam works. I forgot to do the mod for the high beams to work with the low beams. I however cannot remove the module back. There is no room to squeeze both ends of the module to pull it back. How can I remove the module??
 #75830  by Red Baron
 March 16th, 2005, 9:49 pm
Trade secret! You have to make a tool to access the back side.
 #75834  by kumiyer
 March 16th, 2005, 10:26 pm
Alright, you know I am gonna ask you to share your secret. What do I actually need to do.
Is it squeeze the tab on the other side just like one on the outer side.
Or pull the tab on the other side
Or is it something completely different.
This is driving me nuts, I tried about 20 minutes in removing that and all I could remove is my skin and flesh of my body. I am not joking on this one.
