Hello,
I changed spark plugs on my LHs to NGK laser platinums as per FSM -- apply anti-seize to threads, torque to 20ft/lb (240 in/lb). Afterwards, I come across the following on the web:
http://www.ngksparkplugs.com/pdf/tb-063 ... isieze.pdf
http://www.clubprotege.com/forum/showth ... e-Compound
From quick Google searches, it becomes apparent that pretty much all spark-plug manufacturers advise against anti-seize. OEM spark plugs appear to have been installed without anti-seize. Did not encounter a seized spark plug on any of my LHs, including the one that had around 180K on ORIGINAL champion plugs. FSM appears to indicate that anti-seize is needed, however, in light of the above, I am starting to wonder.
Any thoughts?
Any thoughts?
