  • Transmission Filter
  • Speed Sensors and ATF+4 and the like
ROM Banner
 #316157  by MAD King
 August 26th, 2013, 4:20 pm
Hello all,
I tried to locate a thread where a filter for the tansmission is recommended, but I have either tomatoes on my eyes or there is none.
What filter do you recommend?
Thank you
 #316159  by MAD King
 August 26th, 2013, 4:30 pm
I looked at this before I posted my questions and thought that can't be a good one.
But if FIREM recommends it then it must be good.
Thank you
 #316161  by M-Pressive
 August 26th, 2013, 4:36 pm
Maybe others will chime in but his word was good enough for me. He even installed it!
 #316162  by FIREM
 August 26th, 2013, 4:39 pm
Same filter in both my M's, no issues, Proper fluid is the real key.
 #316163  by MAD King
 August 26th, 2013, 4:43 pm
If this recommendation comes from FIREM, there is nor arguing about. ;-)
 #316164  by MAD King
 August 26th, 2013, 4:55 pm
Another thing. What Fluid? Castrol, Walmart, Mobil, Mopar? And where to get it for a good price?
Thank you
 #316179  by FIREM
 August 26th, 2013, 7:50 pm
ATF + 4 Period, nothing else.
Walmart often has Mopar branded or "Super Tech" brand +4 for good $$
(FWIW ATF+4 has a unique smell and the label has all the proper ID info )
"Super Tech" +4 in both my M's, and a few others, without any issues (160K/140K)
 #316186  by MAD King
 August 26th, 2013, 8:28 pm
Great. I'll go with the Walmart Brand. Thank you
 #316286  by grayslater
 August 27th, 2013, 8:12 pm
I've used the Pro King filter from AAP many times over the years. It's a rubber gasket. Wix has always been a quality oil filter in my opinion but I did not like their cork style gasket.
 #316309  by MAD King
 August 28th, 2013, 7:40 am
I see that the filter is AAP own brand. Do you mean the gasket is still cork?
If so, where do I get a rubber one?
 #316317  by FIREM
 August 28th, 2013, 9:46 am
Rubber reusable Dealer Item only $$ I use the rubberized gasket in the kit, no sealer, clean and dry.
 #316322  by LUNAT1C
 August 28th, 2013, 11:21 am
He said the Wix oil filter uses cork. Pro King trans filter from AAP uses rubber.
Had I done my own filter change (parking lot is not a good place to do it, so I had the dealer do it) I would have a Pro King filter with AAP-branded ATF+4. Since I had the dealer do it, I currently have whatever they used, assuming Mopar filter and Mopar ATF+4. I did specifically ask what fluid they use since it's rare for an LH to come through their service department anymore and the service writer smiled and said "+4" with zero hesitation, so I know they were on the ball. Expensive to have them do it, but it's worth the piece of mind that some random kid hired by a small shop thinking "Well this bulk stuff we use in the Hondas, Fords, GMs, Toyotas, etc. works fine, I can dump it in this Chrysler, +4 is an old wives tale blah blah blah" isn't monkeying my transaxle and making me dump a few grand that I don't have into the car when the trans implodes.
I'm told that any bottle with ATF+4 on the label will do, since it all comes from the same refinery/lab/mixing facility that is certified by Chrysler to make the fluid, with whatever label the brand puts on it. Personally I detest Walmart so I don't give a rats hindside how much cheaper it is. I'll be adding the AAP stock that I have when I pump out the fluid in it currently and refill (3x, half the fluid is still in the TC) as my fluid change. Check AAP, AZ, O'Reilly's, and whatever auto parts store is local to you.
 #316323  by Bill Putney
 August 28th, 2013, 11:23 am
FIREM wrote:Rubber reusable Dealer Item only $$ I use the rubberized gasket in the kit, no sealer, clean and dry.
The dealer alternative (to the "special" tranny fluid RTV) is actually a metal and silicone sandwich gasket (vs. the aftermarket all-rubber gasket) - and yes - a little pricey. I put one in my '99 over a decade ago (still in it) - it was around $30 then. I believe it lists for over $60 now.
 #334550  by jayman2
 July 9th, 2014, 10:46 am
I realize that this is an old thread, but I have a question. I'm getting ready to have my have my trans filter and fluid changed. My trans seems to be performing just fine, just a little PM. I'm going to get the automatic transmission kit that FIREM recommended. My question is... I had my last trans fluid change done 3 years or so ago. At the time I didn't know about the importance of using ATF +4, so I don't know what the shop used. If they didn't use ATF +4, can I just get a drain and refill with the ATF +4, or will mixing different fluids harm my trans? I keep reading on here that a trans flush is not recommended. The stuff I have in there now is a pinkish, redish color. That's all I know.
