  • fuel supply line p/n 5083036ab
 #351797  by zimdog
 November 16th, 2015, 11:53 am
Dose anyone know where I can find this fuel supply line p/n 5083036ab
 #351809  by M-Pressive
 November 16th, 2015, 7:15 pm
Jim Click Dodge
Tucson, AZ 85705
H W Hunter Dodge
LANCASTER, CA 93534
Both of these dealers show the part in their system. Might be worth a call to see if they actually have them, they should ship it right to you.
 #351835  by zimdog
 November 17th, 2015, 11:31 am
called both dealers they no longer have the part I have called lots of dealers the part is no longer available thru Chrysler
 #351836  by zimdog
 November 17th, 2015, 11:33 am
I need help finding this part???
 #351837  by M-Pressive
 November 17th, 2015, 11:34 am
zimdog wrote:called both dealers they no longer have the part I have called lots of dealers the part is no longer available thru Chrysler
I did some research for you yesterday and could not find any on eBay.
I use Partsvoice and it is usually pretty accurate with dealership part inventory.
This could be a problem as our cars get older.
You may have to go to a yard and pull one that is in good condition.
I can't think of another option at this point except continuing to check eBay.
 #351838  by M-Pressive
 November 17th, 2015, 11:38 am
I sent a message to this dealership-
H W Hunter Dodge
LANCASTER, CA 93534
It says they have two in stock. Figured I would check in with them just in case.
I am at work and unable to call but I will let you know if they email me back.
 #351839  by zimdog
 November 17th, 2015, 11:45 am
Keith, Thanks so much for your help with matter.
 #351896  by FIREM
 November 18th, 2015, 4:04 pm
May have no choice other than replace the plastic part with Fuel Rated High Pressure Hose. Must be Fuel Rated Working Pressure 50+ PSI.
(There are aftermarket ends and adapters available but I need to check size first)
You may be able to slice the plastic section off the pipe and the quick disconnect but MUST be sure of the hose and clamps used and protect the hose from chafing.
 #351964  by user97
 November 20th, 2015, 4:18 pm
I've been told it is still available. New part number is 5083036AC -- list just under $80 and is apparently still orderable.
May be I was given the wrong info.
Just my 2 cents.
 #357895  by John Galt
 May 1st, 2016, 10:43 am
HI Folks. I need some help in this area if you please. Would this be the same part number for a 2001 as far as you all are concerned? The reason I ask is that the part number I got from the dealer, and I got the printout from his computer to validate that, is 05010225aa, now revised to ac.
While I don't have the smell, I've been wondering about my gas mileage lately. A combination of reading about this issue, plus, now that I think about it, I seem to have seen a few times an odd puddle under the car under the passenger rear door'ish, but the car's acceleration still seems very good, not to mention I don't want this beast to catch on fire brought me to this conclusion.
So I thought I would ask the group
 #380616  by HazMat10904G
 September 7th, 2019, 6:09 pm
user97 wrote: November 20th, 2015, 4:18 pm I've been told it is still available. New part number is 5083036AC -- list just under $80 and is apparently still orderable.
Just my 2 cents.
Hi, I need help finding PN 5083036AC Fuel supply line for 2003 Chrysler 300M. Please reply. 9097868639
 #380622  by adu1982
 September 8th, 2019, 12:16 pm
Looks like is still available....probably even your local dealer might have it/order it.
https://www.moparpartssurplus.com/p/Chr ... 225AC.html
Sent from my moto g(6) using Tapatalk
 #385395  by DYY986
 August 7th, 2020, 12:20 am
Has anyone attempted to replace the fuel line? It looks like this part is one piece that goes all the way from the tank to somewhere behind the engine. Can it be done without lifting the car?
 #385396  by adu1982
 August 7th, 2020, 6:47 am
Can't really be done without some lifting.....you have to get underneath. What I did is I put it on my driveway ramps. I have two that I made (wood) and two I had bought. You can't drive my special on the ramps so I lifted each side then put each tire on a ramp. With that space I was able to replace it. Hardest part is getting it at the engine side ....the rest is easy.
 #385397  by EasyRider300M
 August 7th, 2020, 4:00 pm
Is it necessary to lower fuel level at all?
 #385402  by adu1982
 August 7th, 2020, 8:34 pm
Don't remember that I did...all I did was just relieve the fuel pressure that was in the line...
 #385466  by DYY986
 August 18th, 2020, 3:00 am
Can anyone verify that 5083036ab and 05010225AC are the same?
 #385470  by M-Pressive
 August 18th, 2020, 7:07 am
DYY986 wrote: August 18th, 2020, 3:00 am Can anyone verify that 5083036ab and 05010225AC are the same?
Nothing I see online shows them being the same. They may be but I am not able to confirm.
5083036AC replaced the AB version at some point as well.
