I had a thermostat fail last year that cost me a radiator in a hurry. I guess it was old and probably would have failed anyway. When I changed my timing belt and water pump, I changed to a fail-safe thermostat. Motorad - made in Israel.
I can tell you the fail-safe function of the thermostat works flawlessly. The problem is that it locks itself open at about 181 degrees, or some temperature very close to operating temperature.
