  • Will 300C rims fit on a 300m ?
  • Wanna put on some cool treads?
 #370068  by M-Pressive
Not with the tires that are included.
The bolt pattern may be similar but there is a 7% difference is diameter (assuming you have 17s now).
 #370069  by delorehal
Thanks
I only have 16" rims, I don't care about the tires because they are dead.
However I readed this thread : http://www.300mclub.org/forums/viewtopi ... 00c#p73296
Bolt pattern and offset seems to be différents and they said that using 300c wheels on 300m will lead to problem
What do u think ?
Does anyone use 300c wheels ?
 #370070  by M-Pressive
I have Chrysler 300 wheels on my M but they are from a different year.
The bolt pattern is a little different but they bolt on just fine. I am not sure anyone has used the specific rims you are asking about but maybe someone can confirm that they will fit.
 #370121  by Sneke_Eyez
The key is whether the LX (that would be the 300/Charger/Magnum/Challenger) that the wheels come from is all wheel drive or rear wheel drive.
Rear wheel drive wheels fit the LH cars. I believe that all wheel drive rims do not. I have never tried them, but I believe they have a different offset which prevents them from being used on an LH vehicle.
I recognize the rims you are showing as Charger wheels, but I can't figure out whether they were RWD or AWD.
 #370354  by KCChrysler300
19" is awd, 20" is rwd
Sent from my SM-G920P using Tapatalk
