  • old style ABS wheel speed sensor usable on newer 300M?
  • Talk about changing your own brakes
 #387735  by telenova
can someone tell, if the old style ABS wheel speed sensor on the rear brakes is usable on newer 300Ms above buildyear 2002?
I need a rear left for my 2003. on rockauto there is only the old style available.
 #388703  by LUNAT1C
Visually they appear very different. I would venture to say no. Check 2002 and 2004. When I replaced the expansion valve for my 2002, RockAuto listed the older style, so I had to buy one for a 2003. The design had changed midyear 2002. RockAuto's listings are not perfect.
 #388748  by Sneke_Eyez
I realize in Germany this might be tough, but it seems like a good junkyard pull as I wouldn't want to try to use the older style without knowing it will work.
