Wifes 00 Intrepid ES (3.2L) had a bad injector so I changed that out early last month. Haven't drove it much, but was getting some excessive crankcase pressure. Was blowing oil out of the dipstick. Is it safe to say I should change the pcv valve? Also found out the hose has a bit of a cut in it, so planning to change that too. What hose is recommended for that? Thanks in advance.
