  • Adjusting the sunroof fit.
  • Post about dealer experiences
 #38682  by 99 300M
Actually, this question is for anyone who can answer it, but I thought this would be a good place to post it.Is there a correct "procedure" for adjusting the fit of the sunroof? I know it's supposed to be a little higher above the roofline at the rear, and little below at the front. I noticed mine had sunk down in the rear today, so I tried to adjust it. I loosened all four torx screws and even when I pushed the glass up as high as it would go in the rear, the right side is still a little below the roofline. The left side is at the requisite height, as is the front.
 #230486  by AdamHaskins
uh oh. Same problem as me and hasnt been answered in 7 years :(
 #230492  by FIREM
ADJUSTMENT
(1) Move the sunshade rearward to the open position.
(2) Move the sunroof glass panel to the fully closed
position.
(3) Loosen the forward screws on each side enough
to make the front adjustment.
4) Adjust the front of the sunroof glass panel 1
mm (1/32 inch) below the top surface of the roof
panel.
(5) Tighten the front two screws.
(6) Loosen the rear screws on each side enough to
make the rear adjustment.
(7) Adjust the rear of the sunroof glass panel 1 mm
(1/32 inch) above the top surface of the roof panel.
(8) Tighten the rear two screws.
(9) Check for proper fit. If not OK, repeat glass
panel adjustment.
 #230498  by AdamHaskins
Awesome. Bob, any idea why they say to put the front 1mm BELOW the roof line? It seems like it would leave a crack in the front like there is in the back which would allow water to get in.
